Ignition Timing in 3D
KitCarlson
Middle Tennessee
By reading many posts on this form concerning ignition timing, there are many views on the subject.
When tuning for performance, some often simplify. An example is to lock the timing advance to 32 degrees. That may work in a limited RPM range, for wide open throttle use, but is not optimal. The timing can be easily adjusted, and tests made for lowest ET, but there is still performance to be gained by proper timing curves, meeting engine requirements.
The next improvement would be mechanical advance, followed by the addition of vacuum advance. Going more refined is electronic advance with 3D RPM and MAP table. More refined is the addition of knock control, and temperature timing enhancements. With proper controls, an engine is tactile, it responds to the drivers needs based on throttle position and RPM.
Modern engines use electronic advance, our older engines may be retrofitted with improved ignition systems for improved performance. I have experience with successfully developing engine controls for 4 cylinder normally aspirated and turbo engines. I am now working on a COP ignition for 6 and 8 cylinder Mopars. My greatest concern, is will people understand the 3D nature of tuning to get the most of the system.
The system will be easily tuned while running, from inside the car by pressing buttons. Things like RPM, ignition timing and manifold are real-time monitored values. More on that later. I have done this since 2003 on several cars using my engine management system.
Back to our ignitions as the came from factory, mechanical advance distributors with vacuum advance. They provide a good starting point for tuning. By consulting the factory service manual, distributor specifications can be found and used as a starting point. Mopar tuned distributors based on carb, transmission type and other features such as CAP.
Here is an example for a 1966 Barracuda with 273 2B engine. The 2 2D timing curves are independent of each other. The ported vacuum at carb shuts off the vacuum advance when throttle is closed. I have use this to estimate the 3D equivalent as a staring point for a 3D ignition control. 3D controls rely on a central manifold vacuum source, not ported vacuum, but the nature of the table complexity provides the timing control as desired.
Here are pictures of the user interfaces I have used in the past concerning ignition timing settings.
The first is a bluetooth wireless using my android cell phone.
The second is an application used on my PC via USB cable.
Both incorporate two 2D RPM and MAP advance curves with a third 2D curve that enable a total timing limit vs RPM. It approaches 3D capability, but is easier for those experienced with standard distributors.
If you're dealing with some of us dummies, the answer is a resounding 'NO'... I kind of follow the 'big picture', but the details.... not so much.
Bring it on Kit! Id love to experiment with this on my EDIS six. Getting spark off the megasquirt or diy-efi jaguar board would help in de-integration as well as giving the carb guys a MSD-like programmeable ignition with a simple locked out e-distributor. If it is self tuning or can load a base map, tuning would be easier for the newb.
.............. diy-efi jaguar board ..............
Can you post a link to the source / main website? I got lots of hits , but some are related to Jag "the car" and others are forums concerning this "jaguar board."
Bring it on Kit! Id love to experiment with this on my EDIS six. Getting spark off the megasquirt or diy-efi jaguar board would help in de-integration as well as giving the carb guys a MSD-like programmable ignition with a simple locked out e-distributor. If it is self tuning or can load a base map, tuning would be easier for the newb.
I have you in mind. The COP system will have a Tach and cam output signals. The idea is to then use my existing EMS2 for slant six or V8 EFI applications. My EMS2 is great for 4 cylinders, but by off loading the COP, the ignition drives of the EMS2 can be converted to drive additional injectors.
Sorry I am not a fan of EDIS, the missing tooth wheel, is a step back for me, not going to do that. There are off the shelf 6 cylinder shutter wheels. The COP system is easily changed to 4, 6 or 8 by a couple settings.
My systems do have configuration export and import capability in readable text.
Here is an example for all settings for EFI and ignition control for my Aztec7.
Started, Rate, 0.20, 11:13:41 AM
V5.1,0,0,0,0,1,0
BEGIN
8,8,128,128,12
6,4,2,1,1,1,0,0,0,0,0,0,0,0,0,0
25,25,22,24,28,31,35,36,36,36,35,34,33,32,31,29
42,35,36,40,48,51,55,55,55,55,55,55,55,55,55,54
47,47,48,49,52,60,65,66,67,68,69,70,70,71,71,68
47,47,49,49,55,64,70,74,77,79,82,83,83,84,84,82
61,59,58,58,64,72,78,82,86,88,88,89,90,90,90,88
71,67,65,61,68,77,82,87,90,92,93,94,95,95,95,93
75,72,68,64,73,82,88,93,96,99,99,100,102,102,102,100
77,74,71,69,75,84,90,95,99,104,105,107,108,109,109,107
IGNITION TABLE:
0,0,0,1,1,1,2,2,2,2,2,1,1,0,0,0
0,0,0,2,4,5,7,8,8,8,8,8,8,8,8,7
0,0,1,6,13,19,21,21,22,22,22,22,22,22,22,21
1,0,2,8,14,22,24,27,27,29,30,31,31,31,31,30
2,1,4,9,15,22,24,27,27,28,29,30,30,30,30,29
2,2,5,9,14,20,23,26,26,27,28,28,28,28,28,27
2,2,4,9,13,18,21,23,24,26,27,27,27,27,27,26
1,1,4,9,13,18,20,22,23,24,25,26,26,26,26,25
0,1,4,9,13,18,20,22,23,24,25,26,26,26,26,25
0,0,0,0,1,3,5,7,9,12
50,42,32,10,4,2,1,0,0,1
110,100,95,88,83,77,70,60,50,40,10
56,44,32,22,9,4,2,1,0,0
126,111,102,92,70,54,38,22,12,7
7,6,5,4,3,2,1,0,0,0
2,1000,1500,30,230,4750,5000,32
18,6,70,5
0
END
Stopped, 11:13:42 AM
The igniton table is plotted here plotted using Excel by cutting pasting from table above:
  • Aztec7IgnTable.pdf
...My greatest concern, is will people understand the 3D nature of tuning to get the most of the system.
I do get it. This last summer I built a 2D plot in Excel and began manually recording (hand written log) my vacuum readings at various RPM/MPH. However, my goal is different than yours, my goal is to tune/improve my old school systems (Chrysler electronic ignition, adjustable vacuum advance, Holley carb, and a adjustable PCV). I'm sending you a PM with my email address in hopes you will share your 3D Excel file.
Great stuff!!! Thanks for taking the time for this, Dave (Kit)
You are welcome.
I have attached the 3D 273 file as pdf for clarity.
Attached also is a 3D Ignition table used on my Aztec7.
  • 273Timing.pdf
Hey Kit (Dave),
I made good use of the 3D plot you sent. I used the file as a basis to build my own 3D Timing Tables for my current set up and to use as a tuning aid (another tool in the tool box). No fancy computer electronics on my Demon, just an old school set up that I like to tune.
The first picture is my current set up displayed across a RPM/Vacuum/Total Timing scale. The second picture is derived from the first but I changed RPM to MPH and limited the data so I can see what is going on with timing while I'm cruising in 4th gear (45 mph to 80 mph range). The last picture is another 4th gear view that uses a lighter spring in my distributor to advance mechanical slightly quicker and will probably be my next change.
sure. http://forum.diyefi.org/
Fred the moderator/inventor is a d!ck but you learn to accept him. The whole ECU system in a kit form is under $120 if IRC but you do have to know how to solder SMT or you can buy the SMT already soldered for more $$. reason I went with EDIS-6 was the ECU fires off the cam and my chain was sloppy. Now that I got a new chain, its probably ready to be used with a wheel.
Nice work.
The short time I've been playing with the programmable CB BlackBox ignition I found the tools for altering the timing table quite handy.
You can select a number of cells, either horizontal, vertical or a both, and apply one of the toolbuttons to them, like increase selected cells by 1.
Or blend(smooth) a row of cells with increasing numbers.
Nice work Demon408.
BBM, thanks for sharing info on CB. It looks similar to my ECU I developed in 2003. In your 3D table it appears you have too much timing at high vacuum if you are using manifold vacuum. It might work better for ported vacuum connection.Take a look at the Aztec7 table, to see how timing is limited for low map/high vacuum conditions. Too much advance at light or closed throttle results in herkey jerkey operation. Since the CB system uses a rotor, rotor phasing is important. If it is off, spark could jump to adjacent cap terminal. I see the timing advance is limited to 39 degrees, that is good because with correct rotor phase, there is only about 40 degrees avaliable. It looks like there is 10 as minimum. So you only have 29 degrees timing span, plus base setting. Seems retarding base timing at distributor would be a good step. I am saying all this without reading CB instructions... and could be wrong.
Don't look into the advance numbers too much, I was still focussing on small areas of the table at the time.
The CB system indeed used the rotor as trigger in my case, but it can also be triggered differently by various ways.
Before installation, the distributor has to be advanced a way number of degrees (offset) so the box has enough time to calculate sparktiming based on the table and engine rpm and vacuum.
The distibutor in my 318 has a particuliar issues that it retards a number of degrees the moment the throttle is opened and engine speed is accelerating.
When rpm acceleration is leveling off, the timing also starts to advance again.
This all happens under about 1000-1200rpm.
Mostlikely the intermediate shaft in the engine has some play and moves up or down in relation to the camshaft.
I wanted to compensate this behaviour by using the CB Blackbox to tune around the distr. timingretard.
It was quite an affordable adjustable timing kit compared to rest of the (brandname) kits out there. I've looked at most of them, but either one had something I didn't like, like no vacuum-input, or one had to use EDIS stuff for instance.
Here's another screen of the CB BlackBox-software used to set parameters and calibrate vacuum-numbers;
Timing advance occurs in a locked variable reluctance (mopar electronic) distributor. The pickup voltage output increases with RPM, so the trigger happens earlier at higher RPM. There may be other propagation delays that come into play at higher RPMs. I use an optical or Hall vane sensing means for accurate timing reference signals.
It wasn't really clear to me that the name 'Aztec' was your car. I thought it was how you named the ignition kit, until I glanced at your website.
