I'm looking for a part and can't find it.
MOPARMAGA
A-body or nobody
Yakima Wa
Looking for the plate with an fitting that blocks off the oil pump when using a dry sump.
AR engineering & Mancini used to sell them and now I can't find them.
I will probably make my own of course but I'm not sure what it entails, if anyone has one a could post a photo so I can make one, or just describe it, that would be excellent.
Thank you
Andy from AR Engineering posts on Moparts. I'm not sure if he posts here or not. I'm sure he would let you know what it takes to make them....if they are no longer being made.
I'll reach out to him. Thanks
I laid out a template and just need a -10 fitting
I'll cut out the aluminum and make the part.
Yea making your own seems rather easy. It doesn’t need to be fancy. Just a plate of aluminum with 4 holes and an AN fitting at the bottom. You can get male or female AN weld bungs if you want to weld the fitting in.
Example
Pro-werks AN Thread Weld Bung
Example
Cool thanks, exactly. I just was at a machine shop in town and got some nice scrap aluminum plate.
Even enough to make a dry sump pan.
