AlV
Crabs in a barrel
Greetings,
I need help, yes I know what you're thinking but not kind of help :banghead:
My wiper linkage has got me baffled. I removed the linkage from the car (never actually saw the wipers work) to cleaned them up, install new bushings and send the motor out to passion4mopars to get rebuilt. It's a 3 speed motor with the variable switch in the 69 Dart.
Got the motor back (looks Great!) and installed it back in the car. When I try to connect the linkage it doesn't line up! The link that connects the drivers pivot to the motor crank appears to be a half inch too long! How could this be? If I flip the crank 180 degrees I can connect the linkage but the assembly binds up.
These are the pieces I have:
Do the cranks come in different lengths? Maybe this could be resolved with a shorter crank.
Or maybe the linkage itself can be replaced with a shorter arm.
I'm so confused!
Any thoughts?
Thanks
AlV
- Crank link is a 2822272 with a "32" stamped on the front.
- My Linkage reads 2857937
I'm so confused!
Any thoughts?
Thanks
AlV
