2 Darts
A-body Addicted
I know that you can change the cam in a V-8 with the engine in the car. Does anyone know if this can be done with a /6?
Thanks guys. I was concerned about how the cam lined up with the opening in the radiator support panel. The cam change is for a 73. I'm really hesitant to pull the engine, because it will mean pulling the hood. It's easier for me to dismantle the front end than to pull an engine. At least I know it can be done and that I should be prepared to jack up the engine.
Don't forget to remove the oil pump, and fuel pump(if stock).
Thanks for the reminder. I guess that means pulling the distributor, too. eh?
