indy 360-1 heads stud
I contacted arp a couple months ago about bolts for indy heads.
Here is why i got
"I am sorry, but ARP does not offer a head stud kit for your application . We would need dimensions from the head and the block. I attached a pdf of the calculation sheet, letters C,F,G,H,I are the measurements I would need. if you can get me that information I can see if they have a stud off the shelf that will work for your application."
Some reason I can't get the pic
But " Google arp stud calculation"
I was and am curious as well.
I have a set of w2's and a set of indy 360-1s and I was going to compare them but likely won't get to it till after the holidays.
I'm not near my records for the 360-1 engine, I'm running ARP Studs..
This is the box ( head Bolts) that came with a Complete upper end 360-1 kit. Never used them
Description say>>Cylinder Head Bolts, High Performance, Hex Head, Small Block Mopar, W2, W2 Econo, Performer RPM Heads, Kit
