pishta
I know I'm right....
Just starting to tackle this project..getting the 50+ spotwelds busted is EZ with a rotary spot weld cutter..if you can see them. Now where are the welds in the corners? Im almost tempted to just cut the corners off and grind them flat. Any one ever do this?
