Inquiry: Upper control arm interchangeability 1965 barracuda
1965barracuda1965
New Member
Westport, CT
I'm new to Mopar and am doing my best to learn. My 65 barracuda commando is in need of a passenger upper control arm. I'm in a pickle bc the mechanic wants car out of his shop. I had already ordered one that I thought would fit off of Summit and the mechanic couldn't make it work due to the ball joints being too big.
https://www.summitracing.com/parts/CLP-6374SCA-UK
I'm seeking a upper control arm for 65 barracuda standard drum brakes. We've located an upper control arm but seller told me to check interchangeability. He said, 'All of mine are from 67-up a-bodies. You need to confirm interchangeably. I also have rebuilt power steering box with pitman arm'
Does anyone know of what he is selling would fit a 66 barracuda or the right questions to ask the seller? I'm located in CT and would be driving out to Long Island all the way out east to secure this part.
Thank you for any advice and happy holidays.
all 64~72 upper control arms interchange, they're all small ball joint.
the large joint measures 1-59/64" so something like 1-7/8~1-15/16 with some very near calipers. the small joint is 1.809"
They even go back to '62....all the same regardless of brakes. Just make sure you get the correct side as they don't swap side to side. '73 started the larger ball joint.
