Make sure the rotor is pointing to #1 cylinder topped out on compression stroke, could be the distributor needs to be turned 180 degree's, yes it will start with it put in wrong..
Welcome to this great site, a Good tech will jump in here soon and help.
im pretty sure i got it in there right, tdc compression stroke,dist gear pointing to front right hand bolt on manifold, rotor to #1 plug terminal on cap?
Ooop's #-o That's right, I was thinking about the coil being wired backwards :glasses8:, Makes me wonder #-o So sorry mattchoy.
I knew I was not the tech for this job :glasses8:
WHAT did you do about the conversion? Did you strip out the old electronics and start over, or just try and hook your new dist. to the lean burn harness?
