T67POWER
- Joined
- Sep 30, 2009
- Messages
- 669
- Reaction score
- 10
My radiator started leaking from the top tank so I removed it for repair.
After getting everything I thought I would need the following day,I was thinking I would be done in four or five hours.
Well after cleaning up the mess in the engine bay and cleaning all the old paint of the radiator,fixing it with solder and re-painting it, I was now ready to install my new electric pusher fan on the front side.
I went to install the radiator with the new electric fan on it and couldn't because it hit the engines fan.---to wide.
Off comes the engine fan.
I get it in and try to bolt it in and it hits the center support.
Out comes the cut off wheel to give the middle support a little trim.
The radiator went in and out of my engine bay like 15 times before it was all said and done.
12 hours later and i still have to wire the fan and install a switch in the interior.
It's running and all is well on the car but my back is killing me.:confused:
This is after a few days ago i removed the gas tank to replace the sending unit and filler neck seal.
Where else but on my back in the drive way.
Next i have to replace my upper control arm bushings.
I thought the car was done last fall when i put it away...........guess not.
