I understand what cavition is. I only mentioned high rpm because someone brought up an example of 5,600 (or whatever it was) rpm with a 0.95 w/p drive ratio would run that pump at 8,400 with a 1.4 drive ratio. Not sure about you, but I've never seen or heard of an instance where cavitation was an issue at low rpms. If that's ever occurred, it almost certainly wasn't because they used the wrong pump or pulley ratio. There most likely would've been a catastrophic restriction somewhere in the system. Let's not over complicate things.
My original point was people throw the term cavitation around like it's some rampant epidemic. I've had zero problems running a high flow pump with overdive pulleys. Minimize restrictions by running a high flow thermostat, good quality radiator, etc. and the extra flow will be your friend. But then again, my junk isn't zinging it's guts out for hours on end either.
Yeah, that was me. If you turn 6k rpm with a 1.4:1 overdrive you’re spinning the water pump at 8,400 rpm. With a .95:1 ratio that’s only 5,700. Impeller diameter will affect the maximum RPM rating for the pump. Sure, if you never drive the car hard that never comes up, but that doesn’t mean it can’t be an issue.
Cavitation can be an issue. It’s not as big an issue as just having the wrong pulley ratio for the pump you’re running and that mismatch creating a cooling issue, but dismissing it because you’ve never seen it in an extremely limited application doesn’t mean it doesn’t happen.
It wouldn’t be my first concern for a car, but, saying it’s not a thing because you haven’t personally seen it isn’t a valid argument.
I have a lift off hood , lots of times I just take it off and cruise without it. Not going to lie , other than some odd stares from people , I enjoy it so much more. That hot air just dissipates into the air.
Running without the hood can actually hurt cooling because it disrupts the air flow through the radiator. That’s why there’s typically a seal between the radiator support and the hood. The heat stored in the engine compartment is a relatively minor factor in engine cooling.
BALDERDASH ! !
if you have a vehicle with a tow package to tow a huge trailer, comes with a rad capable of towing up mountains in 100* ambient temp, there is a very good possibility that thermostat never fully opens in nominal weather.
Put that huge firetruck rad in a streetcar assuming it will fit, will that thermostat ever fully open, likely not, - because it has the capacity to supply the nec cold coolant .
I once referred to a raw water marine engine sucking in 34* mountain lake water, - how can that marine engine maintain 140* coolant. (raw water thermostats are usually 140*) , then dump that boat into a summer lake, and still maintain 140* ?
To think the thermostat opens fully, and the radiator is so custom sized that it'll run consistantly within a 10* range summer/winter, uphill/downhill, towing fully loaded/1 passenger, - - is absurd ! !.
The thermostat is as active as your gas pedal on cruise, - more gas pedal, more work, = more heat created, - more coolant flow required thru the rad, - fundamental. - you just don't get it.
Perfect situation is rad cools to ambient temp, thermostat regulates flow to maintain 180?*
I didn’t say thermostats didn’t regulate flow at all. I said you’re oversimplifying the rest of the cooling system and giving entirely too much credit to the thermostat. Which is still true. And now you’re oversimplifying what I said to make your argument easier.
Again, most of the issues talked about here are cars running too hot, and in those
limited circumstances the thermostat is pretty much guaranteed to be wide open. This thread certainly isn’t about what a thermostat does when the water is colder than the thermostat temp, and almost nobody complains about their car running too cold on this forum anyway.
Radiator cools to ambient?! LOL. Not even in a perfect world. Not even close in the automotive world. Most of the time a temp drop across the radiator of between 10 to 20° means it’s good to go.
Seriously, if the thermostat is never fully open what good is a high volume pump? Just run the standard pump and let the thermostat open all the way. A half open thermostat would cut the flow volume more than a high volume pump would increase it.
No DM’s are flying. This is just another cooling thread full of old wives tales, misinformation, and irrelevant examples.
