Installing Custom Roller Cam per FABO reccomendations
I recently read that the Mopar cam cores have wider lobes to better fit the larger diameter lifters... some cores for Mopars have narrow lobes which will affect lifter wear.
I wish I could find that reference material.... Lost it on my phone.
with the taper on the lobe and the radius on the lifter you start off with a line contact
that's why the Hemi and 6 pack started off with less taper and a bigger radius
do you re-radius your lifters?
I havent Jim.
I'd put a 350 hp 327 cam in the thing and call it good...........
Mongo - not like Chebby products !!
sure- get one of these then get your local camgrinder to make a master for your mopar- where do you think he gets his profiles anyway?
3863151 Hyd. – 221/221 --.447/.447 -- 114 – 327-350HP, L79 11:1 40 100 92 48 (88) 3863151
3863151 .447/447 306/306 @lash) 222/222 114LCA 1 41 49 7 (8) @.050 327 350HP TRW TP240 3863151 CS-179R
