installing vynal top trim help
340plot
the bushy bush
va
ok, the dart i am doing had the entire roof replaced with a donor, but the donor does not have the pins for a vynal top.
anyone know where toget those pin like things, and how are the trim held on.
thanks
70 dart
hey joe, i went through the same thing with my 72. someone had ground off the pins and drilled holes instead. i ordered a set of vinyl trim clips for a 71 dart from altha fasteners. worked good. only bad thing is, you have to take out your inside sail panels to get to the side clip nuts. if you need a number for altha, let me know. dave.
okay. went to check for a part number and found out that their closed for vacation till july 9. their no# is 850-762-2179. the kit i bought was a 16 peice kit that only cost 17 bucks. i think they went to the pins at mopar around 72 to try and remedy the ever leaking clips into the trunk. but with todays good silicone sealers, keeping it leak free is easy. worked great on mine. dave.
