Instrument Cluster, Repair or Replace?
Tegner
Member
Snohomish
The instrument cluster in my 67 Dart is in bad shape, none of the gauges work, a few pins are broken, and it's been corroded quite a bit. I'm pretty sure that with a lot of extra time/soldering I'd be able to figure it out, but my question is; would it just be better to buy an aftermarket instrument cluster and hook that up? or should I try to see if I can get this to work?
Run a wanted ad here and you might be surprised. Maybe a member here has just what you need.
Oh and welcome to FABO.
2 main differences between stock and aftermarket are cost and appearence. We cant know how much money you have to spend or what you would rather look at.
