itsdiz
Subject car - 1965 Barracuda. I have had some issues with skipping speedometer and non functioning gauges so I removed the instrument cluster to see what the problem was. A while back I purchased two used instrument panels to use for parts. My original odometer was missing the plastic gear shaft that turns it so I had used the speedometer from one of the used panels and put my original odometer in to retain the mileage reading it had. This is the one that began to skip while driving. I connected another speedometer cable to the back, and inserted the other end into my cordless drill for testing. After cleaning some gunk out from inside the cable hole on the speedo I think I got it working pretty smooth. As for the gauges, I found this - the ground circuit for the voltage limiter had burned or broken free, so I got my soldering iron out and fixed it, tested the circuit with an ohmeter to make sure it was good. I also had to clean up some of the copper contacts with 0000 steel wool to get a couple of the bulbs to illuminate. Another note, this cluster does not have the condensor on it, I am guessing that it was for radio interference and since this car is radio delete, not necessary.
