intake and exhaust valves
boilermaker
toronto
any one experiment with big block exhaust valves as intake valves on a slant head? They are a bit longer than the slant , nothing a quick grind cant fix.
thanks in advance.
Welcome to FABO boilermaker.There,s a few /6 guru,s onboard here that I,m sure will chime in with your needed info.Good luck.:cheers:
Used to be you could buy large valves designed for the Slant (1.70/1.44) from a guy that went by engnbldr on eBay. It's blocked at work, so I can't check, but those have been the go-to setup for Slant guys for years. Hope that helps.
