Intake Casting Numbers
Mrmopartech
St.Lazare Quebec Canada
Mrmopartech submitted a new Article:
Intake casting numbers
Mopar Intake Manifold Casting Numbers 1959-1974
LA, RB/B Intake Manifold Casting Numbers
LA Engine Intake Manifold Casting Numbers
Casting Number Engine-bbl Year Remarks
2465726 273-4 1965
2536636 273-4 1966
2536536 273-4 1966-67
2536771 273-4 1966-67 Calif. Emissions
2531915 340-4 1968
2843683 318-2 1969-70
3462848 340-4 1970
3418681 340-6 1970 Alum. AAR & T/A
2951185 318-2 1970-71
3512100 340-4 1971
3614025 340-4 1972
3671918 340-4 1972 Calif. Emissions
3671918 340-4 1973
3698437 360-4 1973
3698434 360-4 1974
3698435 360-4 1974
RB/B Engine Intake Manifold Casting Numbers
1851898 383-4 1959-60
1851899 383-2 1959-60
2264877 413-8 1959-60
1827899 383-8 1959-62
1947162 383 & 413-8 1961 Left 4-bbl
1947163 383 & 413-8 1961 Right 4-bbl
2205968 383-4 1962-67
2206000 413-4 1962-65
2264877 413-8 1962
2402726 413-8 1962 Max Perf. I
2129985 413-8 1963-64 300J Right
2129987 413-8 1963-64 300J Left
2402726 426-8 1963 Max Perf. I
2402728 426-8 1963 Max Perf. II
2205968 383-4 1964
2402720 426-8 1964 Max Perf. III
2465165 426-4 1964 Max II PL Short
2465185 426-4 1964 Max I PL Short
2468045 426-4 1964 S/S Hemi Strip
2206000 426-4 1964-65 Street Wedge
2468043 426-4 1964 Hemi NAS Track
2536900 426-8 1965 S/S Hemi Strip
2531631 426-4 1965 Hemi/Holley
2946278 426-8 1965 Hemi/Holley
2531921 426-8 1966 Hemi/Holley
2780543 426-8 1966-68 Hemi/Carter
2780544 426-8 1966-68 Hemi/Carter
2206000 440-4 1966
2780543 426-8 1967 Hemi/SS
2780544 426-8 1967 Hemi/SS
2536900 426-8 1967 Hemi NASCAR
2806178 440-4 1967-69
2806301 383-4 1968-69
2536900 426-8 1968 Hemi/Holley
2780543 426-8 1969-71 Hemi
2780544 426-8 1969-71 Hemi
3412046 440-6 1969-70 Edelbrock
2951666 383-4 1970-71
2951736 440-4 1970
2946275 440-6 1970 Early
2946276 440-6 1970-72
3512501 440-4 1971
3614046 400-4 1972
3614014 440-4 1972
3671879 400-4 1973
3698444 440-4 1973
3698442 400-4 1974
3751728 440-4 1974
Read more about this article here...
Here is a 273 "Marine" 4bbl intake,
that is large enough to use an AVS on.
# 2846346
But what type of intake is it,single plane or dual,is it a meadium rise or low rise intake,post some top pics of the intake.These intakes where intended for low rpm use only,as you would normally cruise at 2500rpm,mrmopartech
LOL it looks the same as the 273 4bbl street intake, {Single plane,low riser}
except its has larger carb holes for the AVS.
This intake is great for low end and midrange,but I would think it would be just averange at best.A dual plane alley intake would be better off,Mrmopartech
Well lets get into the time machine, and go back to when it was built;
in 1966 Edelbrock had not yet made the LD4B,
so if you had a 273 small block engine, and wanted to put a larger carb on it
you had few choices,LOL.
Actually those manifolds are good to 6,000 rpm, the low range is where
a single plan is not as good as dual plane. ;)
http://www.autohobbydigest.com/ddart.html
i have the 3698437 360-4 1973 intake that came off a 360, but it looks like its only 2 barrel, should it have 2 holes instead of 4?
I have 2536563? still investigating but was told the engine is the original 273 commando.
also there appears to be a tag that has 11x23
Awesome find, it is correct intake for 273 commando...thanks toolman on info from another post
100_1385-jpg.1714852679
Well, you had the Eddy "D4B", which was the same as the LD4B except it had the old bolt angle and size, to fit the earlier 273 heads.
