straightlinespeed
Sometimes I pretend to be normal
For the life of me I can't remember which way the intake gaskets with the silicone seal around the ports goes on. Silicone to the intake or to the heads. Thanks
I put the silicone seal that is around the ports up and just use copper coat on the bottom side or nothing at all straightlinespeed
Awesome, Thank you gents! Got the intake installed. I hate brain farts!
Don't forget to use RTV around the water ports on both sides of the gaskets. I only use Copper Coat on metal gaskets. Composition gaskets will soak it up and it becomes useless as tits on a boarhog.
I have reused felpros several times. And with no sealer whatever except the standard silicon-in-the-corners.
Have you tried retorquing?
Damn it I didnt! Looks like I need to order a new set of gaskets... again.. Grrr!
Did you put RTV on the threads on the intake bolts too? If not, oil will migrate up them and pool on the intake. Those intake bolt holes go through to the valve cover area inside the heads and need to be sealed.
Good for you. Do those gaskets have the silicone around the water ports? You might be ok. Try it and see. If you see no outside leaks or any water mixing in on the dipstick, you're probably ok.
That's why I always do it regardless. Because if you get an inside leak into the intake valley, it does not take much to dilute the oil enough to spin a rod bearing.
That would suck.
Yes, its the gaskets with the silicone bead. I checked the oil as soon as I noticed it and thank gosh there is none in there! Keeping my fingers crossed, it didnt find its way in.
..........I firmly believe that if u have to use a sealer around the ports anywhere on an intake swap the gaskets are NOT the problem, find what is wrong and correct it...I have never used any kind of sealer and have never had a problem in 40 years and hunderds of engines...........kim..........
RRR hit the nail on the head. Several years ago I quit using the end gaskets all together. I lay a bead of ATV across the block and up around the water ports. I also run a bead from the corners up around the gaskets on the top side. Also Copper Coat isn't intended on paper gaskets.
What's wrong with a little extra insurance? I say nothing, but yall do what you want to with your own cars.
