Intake manifold gasket recommendation
moparmucelli
murrieta ca
hi I have 1970 duster with a stock 360 engine i bought a edelbrock performer 318/360 intake manifold and I was wondering what’s a good gasket set for the intake manifold? Also I bought a 600 cfm edelbrock carb (1406)what’s a good gasket for that ?
The fel pro 1213s I think. I've used them every time and have had good results.
Also any gasket in good shape that fits the carb, and it should be an easy Parts store find.
They're not cheap that I have or use them. I just add extra group the second time. Never a third time yet. okay just thought about it for a second the first set goes on the stroker and then it goes on whatever.
edelbrock 7276....use these mostly these days since they appear to have the largest port window...they do not come with end seal...I just use RTV on the ends anyway.....
Mopar Chrysler SB 318 340 360 Intake Manifold Gasket Set 1213 2.27" x116" x0060" 12933013040 | eBay
I have used the ones above many times too....never had any problems......and they are NOT Felpro despite the 1203 part number
Usually the gasket is not the problem ...it is improper installation is why they leak
Ok great I will check them out
