oldkoot
Well it looks like the front intake seal is leaking on the passengers side and of course it under the A/C compressor so it's difficult to see. I've ordered Fel-Pro MS90009 gasket set (67 273 4V) which I believe contains the steel intake to head gaskets. So before I start there are a few questions-Install the front/rear seals from the kit or use silcone/right stuff and forget the end seals, do the side gaskets go in dry or silicone around the ports, my guess is all intake bolts should have thread sealer.I don't have a shop manual so I'm looking for the torque and pattern to follow, stock steel intake manifold. If it was a Chevy I could do it in my sleep but first time pulley an intake from a Mopar. Anything else I need to watch for??
Thanks,
Don
Thanks,
Don
