Intake question
Will an Indy intake bolt on to W2 econo heads?
If it is an Indy intake designed for the W2, yes it will
Indy sells a rectangle and over port W2 bolt pattern intake.
If your Econo heads have the oval port, order the oval port.
The rectangular window version will bolt to a A2 head but the port mismatch is a big one. If the W2 has been ported into a rectangle, then this is what you want.
It will also bolt to W5 heads.
The Indy is a pretty big intake compared to the victor W2. I think it is 3” taller
Yep! That’s the bad boy! Best of the single plane 4bbl. intakes for making max house power IMO.
The only better intake uses two 4bbl carbs, tunnel ram!
I’ll find out in spring if it is the best. That’s the only thing I’m changing on my car.
