SwingerSteve
Hey guys,, I'm installing a Weiand aluminum intake on my 318,, whats the sequence and torque specs? And going with the cork end seals,, all advice is welcome..
The intake had the cork ends on it when I took it off the old engine so I figured I'd use em again since they came in the gasket set.. But a lot of the guys here on other posts seem to like the "right stuff".. Gonna take it all in and go from there. I appreciate all the input.The gaskets have always worked fine for me...
I read a post about "the right stuff"..Never heard of it but I'm going to check into it. ThanksThrow those end gaskets in the trash..get yourself a can of "right stuff" put a nice 1/4" fat bead on both block end surfaces,also put some around the water jackets on the heads and the 4 corners where the heads meet the block install intake tighten it down..i like to let em' sit over night before starting the motor..
The gaskets have always worked fine for me...[/Q
