lead69
hopeless car junkie
[I did a compression check and got between 170-180 on all cylinders, which is close to Hughe's calculations (see below).]
That is interesting,I have compression tested engines with a true 10.75 static and a relatively small cam (224 @.050) and they ran around 185 cylinder pressure (carb wide open plugs pulled ect.).Im assembling a 408 for a friend this next month and it will be running 9.5 static and a comp xs282,I will be very curious to see what it tests at.
