Purchase some clay. Make tall 5 rectangles. One in the center of the air cleaner on top of the stud. The other 4 put at 12, 3, 6 & 9 O'clock positions.
Close the hood and measure.
If you can, measure the stock set up with the air cleaner installed as if it was on the engine and running. (And if it is, even better)
Use a level and place it on top of the air cleaner in the center. With a tape measure, measure the distance from the top of the block at the front to the underside of the level. Do the same for the rear. Write down these measurements.
Then measure the Torker intake. Use a level and place it in the center where the carb would sit. Measure from the bottom of the front of the intake to the underside of the level. Write it down. Do the same for the rear. Divide by 2 for the manifold height at the center.
With that measurement, add in the crab height, spacer height and the 2 gaskets it will take to seal it. All of this must be added in. If it is less than the hood height clearance, you'll be good to go BUT caution you to take care in closing the hood for the first time. Use clay there again. Close hood slowly.
So long as the Torkers total height with the intended carb and air cleaner are equal or less than the total height of the current set up and the depressed clay used to measure how much room is left over above it, the Torker, TQ and spacers with gaskets are good to go.
It is my *Hunch* that it will not fit. On my '73 Cuda, a TorkerII-360 wod not let a 3/4 inch spacer and a TQ under the dual scoop hood. No air cleaner was used to check this Fitment.
