pishta
I know I'm right....
Thats whack! I never heard this and I ran an RPM A/G on a 340 without incident. I must have cranked the bolts in? But tolerances are all over these motors. To the shop, or back to the old intake...
This is how the RPM intake is. They fit perfect with the RPM heads, but run high on the stock heads. The Weiand Stealth fits stock heads better, but you have to use 2 sets of gaskets to get a Stealth to fit with RPM heads. To get it right with stock heads, youll have to mill the intake about .040-.060" on each side. This is a common and ongoing issue with these intakes and Eddy does not care.
Hm, interesting.
the gaskets are .060 inch thick so I'll try to screw the bolts in without the gaskets and if that fits easily then I'll have the intake milled to the gasket thickness. The tape measure shows to old intake and new intake are 2/16 of an inch off so that would mean it needs to be milled to .0625 inch per side. Is that safe? How much is too much?
I had the same problem with the air gap on my 66 Cuda with 360. It took 3 sets of gaskets and retrying until I got it to work. On the front and rear of the intake I had to use the cork gaskets plus silicone to seal the ends. Just try positioning the intake with gaskets and remember what order you used until you get it to line up enough to bolt down. It never lined up perfect but is on the car. Good Luck fitting it. Not happy with the fit.
