intake ?
unknownsnake
Mason, MI
strange question but do they make a high rise intake in a single carb? if so who and where can i get it?
Actualy, the strange question would be do they make a low level single plane intake for the engine. All single plane intakes are a high rise design. Unless you have a street dominator from Holley.
so what do guys do that have to 6-pack hood and have one carb to get it up there
You can always put a spacer between the intake and the carb to increase the height. Just make sure you know what effect the increased plenum volume is going to have on your engine combo - may be either negative or positive depending on your combination and what style spacer your use.
There's a lot more science that goes into this than just thinking "raise the carb to make it look cool".
i meant whats do they use to get the 6 pack hood is functional and not there for looks
Weiand made a high rise tunnel ram with a single 4 barrel carb plenum along with the dual 4. They still sell the dual quad Hi Ram #1967 for 440's or at least last year. Best bet for the single 4 is ebay.
1st version
Hood
