intakes
DARTLARRY
FORT WAYNE IN
I have a mild 360. 10-1 compression, 293 lunati cam, ported heads with 2.05 intake and 1.88 exh. My problem is with intake choices. I have a ld4b That is gasket matched to 360 heads. I also have a stealth. Which would be a better choice. The carb will be a 750 carter AFB. I also thought about a cam swap, maybe a comp 268. dont know. The rest of the combo is Dougs headers, 727, 8.75 with 3:91 gear. Maybe some of you guys can help me.
Air gap or LD340 would be my choice,and a carb. like a Holley or Quick fuel..not a fan of carter/edelbrock carbs..
