Interior door panels
Roadart
Escalon ca.
Several of the door panel clip slots are broken(gone). Is there a way to carefully cut out and replace the backing? The front material is in good condition(driver quality).I dont want to replace the whole panel if i can fix it.
Doubt you can remove the vinyl and padding and apply it to a new hard board successfully.
You could epoxy the clips in place BUT I doubt they will take being removed from the door in the future.
You might be able to reinforce the area of each clip with a flat metal strip epoxied onto the board?
I run across door panels that the backing board is in bad shape / warped / broken. But the vinyl is in decent shape, some loose and wrinkled up. Think it's possible to peel off the vinyl and re-glue it on to a piece of 1/8" Masonite ?
If you're handy. If I were to do that they would look worse. LOL I just bought repop panels.
Yes.
Is the back side of the vinyl (that touches the hard board) vinyl?
I thought the assembly was hard board - foam - vinyl, then the pattern was melted into the vinyl from the front face.
