[Found!] Interior Door Trim Panles
72DMag
Pittsburgh
Hi I'm looking for the interior trim panel that connects to the headliner. Honestly don't know the specific name. Its a metal piece of trim that goes between the A pillar and the rear sail panels. I need both sides for a 1972 duster. A 70/71 duster should have the same part. Thanks
Are you looking for the metal trims that go over the door opening? If so you are correct 70’-72’ are all the same. I might have a set I will check tomorrow.
Yes it goes on the inside and covers the door opening connecting the a pillar to the sail panel. They should be made out of metal. I know that 70-72 are the same. I'm not positive that 73 and up dusters are the same since they switched to plastic rear sail panels. Thnaks!
Just wanted to try to get a pic of the part I am looking for. Its a metal pice that goes here and covers up where the headliner meets the body. Thanks all!!
pic
