Interior Paint Codes?
toddlaine
Chalmette, La
I have a 72 Dart Swinger exterior is light green metallic and interior is the darker green. I'm doing the interior and want to repaint the interior pieces. What paint code are these colors?
Thanks
It would be on the fender tag and the build sheet if you have them.
Also check the decal on the car for the codes. I don't recall if it is on the driver's door or the area where the door post is.
Thanks
you may have to see if you have a fender tag under the hood near the battery .....its just a little metal plate with numbers on it held on with two screws .....that tag will have your code info
