buffoni88
So, got my intake on with no vacuum leaks, FINALLY. Now, here's my problem. Yesterday, I flushed out my heater core, got the heat back again. I was about to go inside, when I noticed I had about 5 psi oil pressure. HUH? Thermostat was at 195. Just went out this morning, started it up, and had about 60 psi oil pressure, didn't let it warm up to 195 again though, it's too cold out right now and didn't want to stay out there. What would be the first thing I should check? I have an aftermarket gauge, so I know it's not the pressure sender. Any ideas? Should I check the pump/screen?
