MR4V
Just reading the thread posted by Zbojnik I do not have his balancing problem yet.
The 360 I'm building is externaly balanced as I'm using the origdinal crank, rods & after market external balancer, it has everything new so it will be rebalanced.
My question is on the flex plate, I have a new 727 & hi stall with no weights, althourgh I have a set of weights.
Can I run an nuetral flex plate & balance the plate or do I have to run an external flex plate & get the stall converter balanced with the weights?
Is there a template for positioning the weights?
The reason for running an nuetral flex plate is at a later date I wish to run a stroker 408 this way I will only need to buy 1 flex plate.
Cheers
Cheers
