plugger340
Can the driver and passenger glass be used on either side? Can the rear chrome trim be reversed to use on either side?
The glass is flat, so, both sides will interchange. The stainless molding is specific to one side. A passenger side molding will fit on a driver's side glass and can be use on the passenger side.....and vice versa. It's not all that easy to swap that molding though....and get it stay on. I usually use a bit of glue. There are date code and logo differences between them, and both clear and tinted glass to keep in mind.Can the driver and passenger glass be used on either side? Can the rear chrome trim be reversed to use on either side?
Thanks for the info …The glass is flat, so, both sides will interchange. The stainless molding is specific to one side. A passenger side molding will fit on a driver's side glass and can be use on the passenger side.....and vice versa. It's not all that easy to swap that molding though....and get it stay on. I usually use a bit of glue. There are date code and logo differences between them, and both clear and tinted glass to keep in mind.
