Evan Dutch
Ok, so I’m going to replace the clutch on a 318 833OD and I take the clutch housing off. Most of the bolts look like the 1st picture. But one of the bolts look like the second picture. From what I’ve seen to get a set of bolts like the first picture is gonna run me $30 or more. If I put it in like it came out will I have a problem? Or will it be fine. I’ll add a picture of the clutch kit I’ll be using if it helps any.
Thanks.
Thanks.
