I just read a tech talk article that has me wondering if I've made a mistake concerning the rear crank seal when I rebuilt my 273.
The article states the factory rope type seal needs the knurled marks on the rear crank journal to keep the seal oiled and swollen. If a rubber/neoprene seal is used, then the knurls should be removed or the seal will leak.
I used a Felpro rubber seal and there was nothing on the package to indicate the crank should modified before installing the seal. Now I wondering if the seal will leak after a couple of thousand miles.
The engine has not been started, but has been reinstalled so correcting it now is unlikely, but I was just wondering if anybody has run into this.
