killerplymouth
Member
Hello FABO,
my clutch pedal is not returning all the way and (I think) it stops before the clutch is fully engaged, so I need push it all the way up by using the back of the pedal:
I had the car at a shop recently and they recommended a diaphragm clutch (a McLeod street clutch) so I said ok and they put it in; it had a 3 finger clutch in it before and it wasn't doing this.
I see the other recent thread about this topic, the resolution was to remove the Over Center spring. And the pinned thread about removing the OC spring when you change to a diaphragm clutch. Is it clear from my video that is definitely the same issue I'm having with my pedal? Because I have a diaphragm clutch and still installed OC spring?
Should I take out the over center spring? If I do take it out, is it necessary to make a return spring? Also, since the shop didn't know to take out the OC spring, do you think it's likely that the rod adjustment is not correct?
Should I try to adjust the fork rod with the adjusting nut so the clutch fully engages a bit lower in the pedal travel?
Is there any other reason why this would happen I could check? could I have worn the basically new clutch down enough to cause this?
If anyone can give me any advice, I really appreciate it.
