Is my rear end strong enough
Big Block A body Tech
  1. Resto
    Resto Well-Known Member
    99
    50
    Mar 15, 2013
    Ga
    Local Time:
    9:41 AM
    Hey,, I'm restoring a 74 Dart swinger. I pulled out the original /6 and 904 and I'm:sign3: wanting to put in either a 383 or 440.. Will my 8 1/4 rear end be strong enough or will I need an 8 3/4 rear.. Thanks
  2. 68gtxman
    68gtxman I used to reMember
    3,998
    1956
    Jul 11, 2011
    Eastampton, NJ
    Local Time:
    9:41 AM
    Doing a lot of burn outs? Going drag racing? If so, then upgrade. If not, then use what you got.
    You could always just upgrade after you break it.
    • Like Like x 1
    • Leadfoot
      Leadfoot Jane Goodall of the N&P Forum
      22,880
      2689
      May 21, 2009
      Severance Colorado
      Local Time:
      7:41 AM
      They're stronger than a 741. At least they have a larger pinion shaft. It doesn't mean they're stronger but they should at least be comparable. Gears matter. The lower the gears, the less stress they are subject to. What tires?? Slicks at the track or street tires on the street? Last is the engine and drive train. A stock engine converter doesn't hit near as hard as a built engine with a higher stall converter.
      Sorry if I haven't been any help.
      Personally, I think they're plenty strong and will more than hold up. If I'm wrong the worst you have to do is replace it. Which is what you need to do anyways if it's deemed to be too weak.
      • Like Like x 1
      • younggun2.0
        younggun2.0 Well-Known Member
        4,644
        881
        Jan 27, 2012
        federal way, wa
        Local Time:
        6:41 AM
        run it until you get the new combo all worked out and tuned well. when it starts making power and running well the weak links start showing up. if you start replacing parts that will work with parts that are meant for future plans you will have a car that is apart alot longer and cost alot more. i did exactly that and it took me 10yrs to get my car back on the street.
        • Like Like x 1
        • d5667
          d5667 Member this?
          9,281
          943
          Oct 21, 2009
          Mo libs here
          Local Time:
          8:41 AM
          Sure no problem just make sure your Nike's are in good shape
          • Like Like x 1
          • RustyRatRod
            RustyRatRod 30 Degrees Outta Whack FABO Gold Member
            57,269
            26692
            Jun 7, 2010
            Georgia
            Local Time:
            9:41 AM
            BS on upgrading. I have a friend who has a Demon that had an 8 1/4 in it. Car ran 11s yankin the wheels leavin. He upgraded to an 8 3/4 but not because he broke anything. He was upgrading the whole car. He still has the 8 1/4. They are plenty strong.
            • Like Like x 1
            • 72ScampTramp
              72ScampTramp Scamp Tramp
              4,487
              57
              Jan 13, 2009
              Fort Dodge Iowa
              Local Time:
              8:41 AM
              Talk to wormanator. He has a BB duster running 11s with a 8 1/4.
              • Like Like x 1
              • swinger340
                swinger340 Well-Known Member
                2,273
                45
                Jul 25, 2010
                Maine
                Local Time:
                9:41 AM
                Have seen a 72 4 speed roadrunner and a 1/2 ton pick up both with 440s and a 72 swinger with a built up 360 take poundings and do lots of burnouts w 8 1/4s for yrs w/o blowing up. Id run what you got.
                • Like Like x 1
                • Woods74
                  Woods74 Broke Senior
                  6,007
                  217
                  Aug 21, 2010
                  Seattle, WA
                  Local Time:
                  6:41 AM
                  Look into the 8.8 swap too. It's one of the top sticky's in transmission/drivetrain.
                • RustyRatRod
                  57,269
                  26692
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  9:41 AM
                  The 8 1/4 (actually 8 3/8) pinion diameter is 1.625. That's 1 5/8 for the decimal impaired. The GM 12 bolt pinion diameter is........wait for it.........1.625. I've seen 12 bolts take in excess if 1000HP. Course they had good stuff in them. I'll be damned If I would swap in some inferior phord crappola when what you have will work just fine.
                  • Like Like x 1
                  • 66dartman
                    66dartman Well-Known Member
                    1,166
                    6
                    Apr 25, 2005
                    Littleton, CO
                    Local Time:
                    7:41 AM
                    Only thing is those pesky c-clips.... Sure is easier to set one up than a dana, like those adjustable carrier bearing spanners. Should hold up until you break an axle.
                    • Like Like x 1
                    • moper
                      moper FABO Gold Member FABO Gold Member
                      15,645
                      1765
                      Dec 27, 2004
                      eastern CT
                      Local Time:
                      2:41 PM
                      It's not usually the pinions that shear. It's ususally the caps that flex and move. The 81/4 is a decent rear. If it has the gearing and differntial you want I'd leave it and if it breaks, upgrade. If you have to go through it, re-gear, or add a limited slip unit - just upgrade now. I wouldn't spend much on it.
                    • RustyRatRod
                      57,269
                      26692
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      9:41 AM
                      I've seen that arguement before too. But in all my years around cars, I have seen precious few c clip buttons broken. They don't hold a load at all. They simply keep the axle in place. It's a good rear end.
                      I've actually been looking for one for a long time to trade for my complete 8 3/4 sure grip under my 63 Dart, but no one's ever come through. I guess my little slant car will just have overkill, and that's fine too. lol
                    • Oldmanmopar
                      Oldmanmopar Going left turning right FABO Gold Member
                      7,575
                      3261
                      Jan 8, 2009
                      Danielsville Pa.
                      Local Time:
                      9:41 AM
                      Only someone standing close to you could answer this question. Or you could sit in a bath tub and smell the bubbles.
                    • metallidart
                      metallidart member me?
                      1,562
                      216
                      Jan 19, 2009
                      East Palestine, Ohio
                      Local Time:
                      9:41 AM
                      I'm going to go through mine, add a sure-grip, and hope it lasts for a little while behind my 422. I won't be running sticky tires though.
                    • rnaz
                      rnaz nitrous fed 390
                      487
                      23
                      May 25, 2010
                      Detroit
                      Local Time:
                      9:41 AM
                      I agree. I put well over 450hp through an 8-1/4 in a 4800lb truck and ran 12's all day long for years in it. The trans lost 2nd gear before the rear end even blinked at the power.
                    • Resto
                      99
                      50
                      Mar 15, 2013
                      Ga
                      Local Time:
                      9:41 AM
                      Awesome. I bought this car I'm restoring completely disassembled. Rear end as well. I was curious if I need to look for another one. Thank you guys for all the good answers. I'm going to stick with 8 1/4.
                    • wanta68cuda
                      wanta68cuda Well-Known Member
                      514
                      79
                      Jan 30, 2008
                      Cartersville,Ga
                      Local Time:
                      9:41 AM
                      Dang!!! Where were you four month's ago when I was trying to sell or trade my 8 1/4 sure grip!!! That's always my luck. LOL:banghead:
                    • Steve Reynolds
                      Steve Reynolds Member
                      20
                      0
                      May 30, 2007
                      S.E. Texas
                      Local Time:
                      8:41 AM
                      We drag race a 71 Demon, 440 rb 727 & 8 3/4, 4.30 gear, runs low 10's on foot brake. Broke 2 ring and pinions and cases (489) and 1 sprag. Going to a dana cause I put in a trans brake, don't want to take any more chances.
                      Steve
                      • Like Like x 1
                      • RustyRatRod
                        57,269
                        26692
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        9:41 AM
                        If you didn't put a crush sleeve eliminator in that 489, there's your reason. 489s with crush sleeves and 742s usually hold up at those ETs.
                      • inkjunkie
                        inkjunkie Well-Known Member
                        17,014
                        2116
                        May 24, 2009
                        Local Time:
                        6:41 AM
                        Or just cup your butt, let one rip and smell your hand......just in case you do not have a tub in your house....
                      • Steve Reynolds
                        20
                        0
                        May 30, 2007
                        S.E. Texas
                        Local Time:
                        8:41 AM
                        Crush sleeve eliminator was in both 489 cases, the main cap on right side broke both times, but after 400 + runs & more the ring & pinion & the case said enough.
                        Steve
                      • womanator
                        womanator Well-Known Member
                        533
                        12
                        Jan 1, 2007
                        Local Time:
                        8:41 AM
                        74 Duster full interior.
                        We call it the trainer car because you have to learn how to cut lights before you get in one of the faster cars.
                        8 1/4 rearend with 3.91 gears and sure grip.
                        Smog engine with a few up grades.
                        Runs 12.21 off the juice and 11.59 with 100 hp of juice.
                        Well over 300 pass's with the 8 1/4.
                        Waiting for it to brake.
                        Road hard and put away wet.
                        3200 lb car.
                        Trainee Jon.
                        [​IMG]
                        [​IMG]
                        [​IMG]
