I have a friend building a 1971 Dart with a 383 and a 727. Is the column shift linkage the same as a 340 if they are both 727s? If not, does anyone make column shift linkage for a big block in a Dart?
yesWill a column shifter fit with a BB?
Consoles weren't standard on a 69 GTS. Buckets seats were but the centre console was an option. 68/69 GTS's were available with a 383 big block so I'm under the impression that yes there was a big block with column shift. Also I'll add that the standard seat in either a Dart GT or GTS convertible was a bench seat. So it's possible for a GTS 383 convertible with auto transmission had a column shift.I’m not sure that they ever built a big block A-body car with a column shift since they only offered them in GTS’s, Formula S’s and ‘cuda’s which were available with consoles as standard.
could you get a floor shifted automatic without a console?Consoles weren't standard on a 69 GTS. Buckets seats were but the centre console was an option. 68/69 GTS's were available with a 383 big block so I'm under the impression that yes there was a big block with column shift.
