racerdude5
Do small blocks, poly 318s, 392 hemis, and 426 hemis have the same diameter distributor holes? Also, does anybody know the different shaft lengths and gear sizes?
Id have to see that to believe it. I know the spacer is made for a RB distributor in an B block, but you'd have to get lucky making the short B distributor fit in an A block unless it just barely made contact with the drive gear. Not to mention the wrong rotation.
Early 392 Hemi interchanges with small block mopar. Never tried anything else.
I'm going to run a 392 Hemi magneto with the small block gear pressed onto the shaft. I'm running a dry sump so the longer shaft of the 392 hemi will hopefully be long enough that it will sit inside the bushing and I can then avoid running an intermediate shaft.
Edit: also the advance system may not function if you turn the dizzy backwards. I have not looked at a factory dizzy since 1981 in less it was to remove and replace it.
Whose mag is it?
As far as rotation, it don't matter if it's cow or ccw. Just wire the cap correctly. That's how RRR's buddy ran a 383 dizzy in a small block. IIRC the shaft lengths are so close between the A and B engines they can get swapped easily.
Not only would the centrifugal advance not work the vacuum advance would be working the wrong way.
