Is the factory 1972 318 internally balanced?
dibbons
La Paz, B.C.S., Mexico
I see the same harmonic balancers advertised for 273, 318, 340 and wondering if the same application fits a '72 318? Thank you.
Timing marks will be in different places depending on the model year/timing covers, but by ‘72 I think they’re the same as all the later model stuff.
Several different ones were used, but, they will interchange with minor mods. '69 and earlier have one pulley bolt offset, and the timing slot is on the passenger side. The '70-1 also has the one offset bolt, but, they moved the timing slot to the driver's side. In '72 they went to the even bolt pattern and kept the timing slot on the driver's side. With a rat tail file, you can elongate the pulley hole to work with either setup. The timing slot would have to added or remarked to use with whichever timing indication you have.
