Ok I like to get all the opinions as possible on my break in of my big block 400 in my 73 Charger. Eventhough this is a Slant Six column, I'm sure some of the tech probably applies to all these Chrysler engines. I'm almost finished up with my 73 Charger and then it will be ready to roll it outside and initially fire it up and do the "cam-break in". The engine ran good when I got the car 5 years ago and I've slowly been doing everything to the car. Facts about this motor are it's a 76 400 passenger car block .040 over, .010 over on the crank. What I did to it was have the block cleaned, crank polished, honed block, new cam bearings, and a Speed Pro Cam put in. It's a .458/.460 lift which according to Sealed Power was the factory replacement. I put a new HP Melling Oil Pump, Milodon stock replacement pickup, Mopar Performance Windage Tray, Sealed Power .010 over bearings, Cloyes OEM replacement timing set, new Elgin 400-4BBL stock replacement springs, reconditioned 73 heads with 3-angle valve job, stock 73 400-4BBL iron intake, 73 HP exhaust manifolds, Reman TQ 4BBL, and stock Reman distributor. So I've read about many different intial break in procedures requiring the engine to be revved to 2000RPM for 15-30 MINS. I've read procedures that say add a quart of Mopar Crankcase Conditioner let the engine idle until warm and take it out and accelerate from 30 to 50MPH 10 times. Some old timers have told me about the 2000 RPM deal and then some have told me just start up and let it get to operating temperature and just get it running good. So who's exactly right? The cam instructions do say rev it to 1800RPM for 15 mins, but the ring set instructions say to load it up from 30 to 50 MPH 10 times. But if that is both correct what do you do first? My barber who has built race motors, stock motors, and even fabricate hot rods says just put some good oil in, an additive, crank it up and let it get to operating temp and make sure it runs good. He said back when they were building these cars the manufacturers didn't do all that when the cars were built. He said they just put oil in and fired it up. So is there a correct way? It's my first rebuild so everything could go wrong, but it just sounds like starting it up and revving it up to 2000RPM right away would be destructive. What's the theory behind that?
