Ragnar in Iceland
Member
I recently bought a 1969 Barracuda 360 with a 727 trans. She was originally 318 with a 904 trans. Car has center console with the original shifter.
There is one thing I need to figure out: If I disconnect the shifter and move the control lever of the trans only, it goes into all gears and park so the trans is fine. But if I connect the original shifter to the control lever and shift into gears I can either hit only park, reverse, neutral, drive and second, or only reverse, neutral, drive, 2nd and 1st. It just depends on if I connect the shifter to the control lever when the lever begins in park or 1st (i.e. fartest to the right or left). My guess is that I need to modify or change the upper rod mechanism. Can anyone clarify what I need to do?
Thanks for responding
Ragnar in Iceland
Ragnar in Iceland
