mikeg1955
I HAVE A OLD PURPLE SHAFT CAM THE # ON THE CAM IS 951107 PLEASE NEED HELP MIKE
purple shafts usually didnt have useable part numbers. You can determine what it is by measuring the base circle and the lobe and taking the difference as the lift, multiply by 1.5 for effective valve lift and go to purple shaft catalog and match it up. duration is difficult to determine but lift is pretty easy.
I do not know of any purple shafts with a 9xxxxx number
but I do have a pretty good list if you do the measurements as suggested above
would help to know which engine
I just updated the Direct connection cam page with additional LA camssee
Direct Connection Cams
for a big block you might want to also post in the B Body forum once you get your measurements
