Is this a good idea?
75dart se
Member
Manitoba
Hi everybody! I've got a 75 dart se that was purchased brand new by my grandmother. I inherited this car 6 yrs ago, did some bodywork and repainted. It's a super nice car and I never want to get rid of it. But I did some mods to the 318 and it's just not working for me. I also have a 68 383 that was in a Newport my dad owned since 1970! I drove that car for many years but eventually pulled the motor because of rust issues. Was a great engine and trans. So I'm thinking of buying a schumacher swap kit and putting the 383 in it. My dart already has 2.5 inch dual exhaust and disk brakes so I think it's a logical swap! Just want a nice driver! Kind of a sleeper. Is this swap as easy as it sounds? Can I retain my power steering?
No reason to buy Schumacher mounts for that car. Build a DC k-member. You have to cut and drill on that K-member for the Schumacher mounts, anyway.
http://www.bigblockdart.com/techpages/dck.shtml
[ame="http://www.youtube.com/watch?v=mnaM_jHLi08&feature=share&list=UUqvjc-8llEE-JKNFYw30-NQ&index=5"]DC K-member 04 part one a.mp4 - YouTube[/ame]
Newport 383 is not going to have much more power than a drop in mild 360, more torque though. I would say no but I already did it too.
Well I have the 383 and would really like to make use of it, will have factory 4bbl on it also. And I know it's history.
exhaust will be your biggest hurdle. If you want to, go for it
In this case with the parts he's already got, I could get it in and running for under $1k, well under. Cost might go up a little if the car has a 7-1/4, but that would need to be changed for a 360, too.
I like the idea myself... Driving a car around that has connections to your dad and grandmother... It will definitely be worth the cost and effort...
I have a friend with an original '73 Dart Sport 340 who swapped in a 383 just by swapping in spool mounts from a '76 Cordoba. A '75 Dart should have spool mounts as well. Go for it!
I say go for it too, A stock 383 will have more grunt then a low compression 360 of that era, If you did go with a 360, pass on the earlier LA engines, go right to a Magnum engine, higher compression, better heads, roller cam, "win-win" on that one. I ran 12.5s @ 105 with a stock bottom ended 95 360 magnum, just bolt-ons, 4.10 gears & 2800 stall shifting at 5K, On a 100 shot it ran 7.3s @ 96 in the 1/8 on a not so clean pass. My goal was getting it to 7.0s @ 100 shifting at 5K.
383s run VERY strong for there displacement, don't under-estimate there potential, A mild cam, bolt-ons, alittle gear & stall, you'll have a solid 12 second A body.
Let me add, I had a stock 74 360 Dart Sport, it was a 4sp. car, It ran pretty good, But i installed a 75 400 in a 72 Duster, it was out of a Newport, This engine was bone stock, right down to the stock 2 barrel & Exhaust manifolds, it even had single exhaust LOL, stock rearend & 12" stock converter, that car was a handful on the street with its torque, Would definitely out run my 74 360 Dart, Stock 400s had a whopping 7.8.1 compression too.
Go for it! You don't need to use the "Abody big block headers". Just use the HP manifolds - which work much easier in the low deck 383 in an A body. Yes, you can keep the power steering. Also, you can keep a column shift if you like.
This is my exact plan for my '75 Scamp as I get the bucks together. I have a 68 383 on a stand along with a 727. I already replaced the 7.25 with an 8.75 rear.
That's the thing! The Newport brought me home from the hospital when I was born,and I got my license in the dart! This is the reason I love the old mopars so much! I would like to do this once and do it right, and drive it lots. I went too far with the 318 and realized I'm beating a dead horse. I saw the 383 on the stand in the corner and figured what a great idea!
I know of a set of hp manifolds from a 68 Monaco, will these work? My car already has 2.5 inch duals with roadrunner tips and it was a nightmare to install! I will try to post a pic of my car.
