TylerW
Hey guys:
I've got a couple steering columns here in front of me. One is a '73 and the other a '75.
I was comparing the harnesses in each and everything appears identical except for a couple things. I think i know the answer to my first question but I'm not sure:
On the '73 all the wires from the ign switch go to the flat white connector and then onward from there. On the '75 column, the wires are identical, except that the heavy red and heavy black wires bypass the the flat white connector and terminal in their own 2-wire black connector.
I'm pretty sure that's the "bypass" to keep those wires out of the bulkhead and avoid the known issues. I *may* have the underhood part of that harness..either way, would it be worth my while to use that harness in the '73 car which has no power accessories, or save it for another day?
The other things I noticed was the '75 has the orange wire present in the ign harness, the '73 does not. Also, the '73 has a 3-wire green/tan/brown harness coming from the column which was not connected in the car.
Thanks for any thoughts.
