67Dart273
Today was COLD. I just came in at 3:30 it is about 19F. I thought I would maybe install the frost plug heater in the Dakota (didn't get done) and install some bed anchors. Bear in mind these little guys don't have stake pockets, and the only front bed tie downs are recessed into the floor of the bed. I have been thrashing around and finally found "something" at "North Forty."
Cut and drilled some strap and welded the nuts on. Hung a scratch awl through the hole from the bed, clamped to a vise grip and held with welding magnets. Then reached up with "great effort" from the bottom up into the void and hung the nut plate on the end of the awl.
Took me SIX TRIES on the driver's side, that is where the fuel tank is, so there's less room.
Something I plan to do is loosen them up and work a slit piece of plastic tubing over the "axle" of the D ring so the darn things don't rattle
