OK deal! I will ship it out friday. It's a 1000 cfm and is supposed to have dominator metering blocks. On the chasis dyno the 1000 race demon was jetted at what I thought would be about right. The 1st pull was 471 HP and it was way rich. I jetted down several times and ended up with 545 HP with basically jetting and swapping from a straight 4 hole spacer to a HVH 4 hole tappered. Patrick said the indy heads were very efficient and with my set up I needed a special set up to counter the efficiency, hence the the dominator metering blocks. I have not had his carb on the dyno and did not get a chance to run it against the Demon at the track so I don't know how good it really is. It has great throttle response but if you look at the videos at the track it looked rich and obviously needed tuned on, just didn't have time. I will also send a copy of the spec sheet I got with the carb. Let me know when you get it.
Thanks Jessie
Brett
