jeep and dodge ram transmission
Dakota_Don
Hi all, i need to change fluid and filter in both my dodge ram 5.2 and 04 jeep grand cherokee I6, they both have pans that look like the 518/727 i beleive they are the 46rh, anyway would either of these transmissions benifit from a VB kit upgrade?
both already have coolers installed and both of them tow a lot.
thanks
Don
Can't hurt. They had some issues that the Trans-go kits resolve and extend their life.
bTW: Are you positive that Jeep has the same trans? I thought they went to the 45rfe or 545rfe by 2004.
I think you may be right, the pan is same shape as the 727. I will check before i purchace parts.. Just currious if they would benifit..
0pps its the 42re, according to google, which is based off the a500. me sooooooooooooo wrong, guess i should have looked closer at the pan..
anyway i am all for longer life..
