T67POWER
- Joined
- Sep 30, 2009
- Messages
- 669
- Reaction score
- 9
I was thinking of advancing my cam in my 360 for more cylinder pressure.
The first thing i was going to do was check my piston to valve clearance by installing checker springs and measuring with a dial indicator.
Well --- when i filled the cylinder with air and compressed the valve spring, the keepers wouldn't budge because they are STUCK to the retainers.
The air pressure (100 + psi)does not hold enough pressure when i smack the valve spring tool with a rubber hammer.
The valve opens instead of the keeper breaking loose.
The keepers are locked in the retainers pretty good.
I did try a second intake valve with the same results. :?
The engine has been together a very long time and i didn't feel like going for broke ,so i put it back together.
The simplest things sound so easy don't they????
Does knowing when to turn back come with age or am i just becoming lazy????
I only worked at it for an hour or so.
I put it back together and started it up and once the lifters settled down ,sounded great.
I keep hearing the little voice in my head say DON'T FIX IT IF IT AIN'T BROKE.#-o
