F-16 is 26,500 lbs empty, those engines are making the HP but its not called out in HP numbers but thrust, too bad. It likely make 600 HP look like nothing at all
Specs don't show how much fuel is used every minute while at full power
It should be easy to convert HP from thrust, you can convert HP to just about everything else, IE electrical wattage, etc
Back in the 70's, we had the "first" gas, uh, ...................crisis........
I remember I found out how much an F4 Phantom II used in fuel, and back then, my 440 RR used to get 12-14 mpg. I remember I figured I could run my car a whole year on what an F-4 used on one mission.
