carmanfast68
New Member
when i drive the speedo jumps around i think it a 727 trains built by tci it has a 29 tooth gear in it that looks good how do i test the cable to see if it's good any help would be great.
Best solution, plus I used WD40 to help it travel down the sheath. Same graphite as is used in door locks. Hardest part is getting the instrument panel out far enough to pull the cable. Rest is easy. That's what I did with my old 71 Swinger. Speedo bounced and made a low noise. Did that and no more problems.Graphite.
